stator
dickie6319
Im trying to diagnose an ignition problem starting with spark to plugs then to kill switch ect.. What is the function of the stator?
delta229
Re: stator
The stator is the stationary part of the system. The rotor when in motion causes the stator to generate electricity. Sometimes simple things like rust building up on the face of the stator will keep it from producing electricity.
Chris1956
Re: stator
To be more specific. The stator contains multiple coils. The magnets of the flywheel spin past the stator coils, creating electricity. This electricity powers the power pack and battery charging system. When the triggers signal the powerpack, voltage is dumped into the coils to fire the spark plugs.
boobie
Re: stator
Rust will not interfere with the output of the stator or flywheel.
dickie6319
Re: stator
So can I assume that if my battery stays charged and the volt gauge is charging that the stator is working?
