I have a 1989 5.4L Mercruiser with Apha I, that started steaming and running hot while out in the bay, i had the water pump and spark plugs changed since then, but engine is still not running correctly. I have the ear muffs and garden hose on it while running it in the yard, the port side of the engine gets very hot while the other side is at normal temp. Steam starts coming out of the outdrive after running 10 min, the boat is also missing slightly and making a ticking noise by the rear exhaust cross connect. Do i have a blown head gasket? or Cracked head?( Oil looks fine) and what is that noise? SOS
