steam
savy453
i have a 5.7 l9 95, i started it today since winterizing in the fall. i have steam coming out of the exhaust, no skip,it got worse after it got hot,head gaskets or exhaust manifold? note no cream color oil all nice and clean tks bob
Ayuh,.... Welcome Aboard,..... If a head gasket lets water into a cylinder,..
That spark plug will be as clean as a new outa the box spark plug,....
So takin' a peek at the plugs may help,....
It could be the manifolds,... pull 'em, 'n look,....
'course, it Could just be yer local weather conditions too,.....
savy453
i first run it up to temp, then drain the exhaust, water pump, block of water,then hook up my pump with a pail of pink stuff into it comes out of the exhaust , them fog it then shut everything down, bag the carb, then i;m done.btw weather is 85 humidity 72 percent sunny
