35 Hp Johnson. The Power Head is a 1980, 35ELCSM, and the Lower Unit is a 1977, 35EL77H.
History;
I overheated this engine. Weeds wraped around the lower unit. I thought I had cleared the weeds and went WOT. Soon I experienced a loss of power. When I backed off, the engine killed and then, Poof! Steam rolled out from under the engine cover. The engine paint blistered and darkened in color.
Compression readings showed 50 psi in both cylinders.
Work Done;
-The head warped, found a used head. Installed head and gasket. Compression readings now at 110 in both cylinders.
-New Thermostat
-New gaskets in exhaust cover
-New spark plugs
* I have not replaced the impeller in the 4 years I've owned this.
All back together and in the water. I have a strong steady stream of water out of the tell tale at any rpm. The water from the exhaust ports is nice and warm, the water from the tell tale is about 50% cooler than the exhaust.
When I'm at an idle everything seems fine. As I add power and increase the rpm I notice that it begins to steam. It looks like a 2 stroke would at 45 deg. outside, but it's 85. It seems to have power loss as well.
There is also some carbon spatter from the steam on my lower unit. This never happened before the overheat. There are pics of this and the holes the steam is comming from.
Could this be an impeller issue? Cracked block perhaps? No sign of dammage to block or cylinders when head was removed.
I'm stumped and getting a bit frustrated. I could sure use some advice, Thanks, Erik
History;
Work Done;
-New Thermostat
-New spark plugs
