stearn drive gear ratio???
benta
1977 Starcraft Chieftan ... I have the motor and stearn drive out of the boat.
How do I know what the gear ratio of the stearn drive is? Several units will bolt up, but I know enough to check the ratio before buying any replacement.
Re: stearn drive gear ratio???
Ayuh,... What motor,..??
mkast
Try this.
benta
the motor is an inline 6 cyl 165hp....GM from the 70's
Don S
You need a 1.65:1 ratio for that engine.
benta
ok....I have the list and the ratio...thanks
benta
regarding the gear ratio question on the stern drive of my 77 Starcraft Chieftan
the engine is the inline 6 GM....I'm pretty sure that would have been an Alpha Stern....right? Don S says the ratio should be 1:65:1....a listing of ratios and the stamp on the stern shaft indicates it should be 1:98:1.
Which is correct is of course one question, but what does it mean in the long run....which gives more power?
