Steering and outdrive questions
bsorge
Greetings, first post on the forum.
I inherited a 1985 Celbrity 225v for free that I am working on. Good news is I got her running. So my current issue is the steering. At the helm, the wheel turns freely. At the outdrive, I can't move the unit at all. I am assuming the latter is because it's hydraulic steering and needs to be moved hydraulically - but that's only a guess as I have another 26' Wellcraft that I can move back and forth (it's a mercruiser alpha one). My boat is a stringer outdrive. When I get the boat started, still no steering. Is there a pump at the helm that I should be looking at? The power steering pump has oil so that is not the issue.
Secondly, as stated above, the outdrive is a stringer as far as I know. It doesn't have bellows like the mercruiser does. It seems that it doesn't trim either. It is either up or down. There is a guide pin on the intermediate unit to hold things in place. So with that being said, how does water get from the outdrive to the engine? I ask because when I did start it, no water was at the engine (yes, I had the muffs on and water turned on). I am guessing there's an impeller that is not working? I have not removed the lower unit yet and I know I need to to service it.
Thanks in advance.
Howdy
Disconnect the drive from the steering and see if drive can be moved.
If it can be moved, then the issue is in the steering and maybe rusted up
