I had stuck steering on my 1994 48hp johnson. It was stuck on the top swivel of the motor. I disconnected the steering cable and took off the bottom motor cover and removed the grease fitting and an allen screw next to the grease fitting(don't know what it is for) and sprayed it with penetrating spray, wouldn't budge so I took a 24" 2X4 and laid it on the arm and hammered it loose(about an hour off and on throughout the day along with the spray. It turns real hard but it does move, I'm going to put a propane torch on it a little to see if it will loosen up more. What process is used to paint a motor like this? I would like to paint the whole lower unit white like it was when new and is it OK to heat this up a littlt to loosen the motor, I can't get grease in the top fitting, I replaced the fitting but it must be cruded up inside and I thought the heat might break it up.<br /><br />Roger in Swansboro NC
