steering and vibration
chkm8
On my way back to the marina I started to pick up a vibration in the steering wheel. If I take my hand off the steering wheel the boat pulls sharply to starboard. If I accelerate the vibration gets worse. The problem started while reducing speed to prevent creating a wake passing a sail boat and there was nothing I can think of in the way of striking an underwater object etc as I was in the middle of the channel and in pleanty of water depth.
The boat is a Finnsport 650 with a mercury 115 outboard any suggestions welcome.
oops!
Re: steering and vibration
check your prop and your annode
mthieme
Yes, you are feeling something from the drivetrain.
tashasdaddy
caheck lower unit fluid, also check and see if it is firing on all cylinders.
chkm8
Thanks I haven't been able to get back to the boat. With work and the weather but am off tomorrow and it is supposed to be dry for a change so will check on all of the above (what is the lower unit fluid ? )
John.
