I am wondering if there is a trick to get the slotted thing off the end of a steering cable?
After the grooved bar that goes on the steering wheel end is a nut. I removed the nut and there is a keyed piece rounded and flat on both ends. If anyone knows what it is called and where to buy one I can grind it off.
Or a way to remove the one that is on there without damaging it. The problem is I don't have anything to hold on to to keep the whole cable from spinning when I try to loosen that piece.
My goal is to pull the core out and clean the tube and cable.
Thank you in advance.
