i have no feed back steering. the engine turns in one direction but not the other. i have disassembled the cables/sleeves from the engine; the engine turns smoothly in both directions. there are 2 cables, one closer to the stern and one closer to the bow. when the "bow" cable is connected the motor will not turn either way. when i disconnect it the engine turns freely in one direction (i had to remove the keeper nut from the sleeve to make this happen), when i put the keeper nut back on the sleeve, nothing moves. if i undue the nut the sleeve and the steering rod slides in and out freely. is the cable just frozen in the sleeve? any answers/solutions would be appreciated. thank you
