Is there any hope of salvaging a very tight steering cable? It seems to be in excellent shape except for excessive force needed to steer. Removed it from boat and cannot push or pull the center by hand. The end has a spiral wrap around the center shaft which fits into the steering wheel housing. There are no obvious kinks.<br /> The motor end shaft can be unscrewed from the center rod but the shaft can't be pulled off the assembly. Thinking of cutting off the lip in an attempt to remove the center working shaft and lubricating.Comments?<br />Jerry
