Well, I thought removing the cotter pin from the clevis pin on the steering cable was the tough part (isn’t that conveniently located!!!), but now I’m trying to remove the cable nut on the other end. Unfortunately when trying to unscrew it, the cylinder it is attached to also turns, preventing the nut from coming off (I’m guessing this is common). I’m not able to get a good grip on the cylinder. Any tricks to suggest?
this is on a 2000, 4.3 Merc
(I’m removing the cable in order to re-grease the shaft that goes through the cylinder. After removing the clevis pin, the steering is still really stiff)
