Re: Steering cable problems
It's pretty simple. I did it on my 89 mariner. Not sure if there is a difference with yours being older but it isn't to bad of a job. Just make sure you get the right length. When and if you pull the other cable out, make sure to tie a rope to the end of the cable (the side you not pulling on). Then when you go to put the new one in you can just tie the rope to it and pull it through. better to bring the cable to the store when you buy or order one so you can match length just in case there are any variances in brands or something.
