motor is a 1996 60hp merc with teleflex single steering. i was removing cable but figured out i didn't have to so put back together. i had loosened all nuts in doing so.
now my steering range when turning the wheel only goes all the way one direction. when i turn wheel the other direction, motor doesn't go as far right as it did to the left. where is the correction/adjustment i need to make? is it in the steering wheel on console or back at the motor where cable goes thru tube with lock nut.
any help apreciated.
thank you
paul
thank you
paul
