robandrews
- Joined
- Oct 8, 2003
- 5
I have a 1979 Sea Ray SRV 200. It is powered by a Mercury 188HP/302 ci V8. <br /><br />My lower unit was hit by a riding lawn mower while the boat was on the trailer. I have discovered the steering is now sticky when turning past "straight" and going to Port. A visual inspection of the steering linkages at the stern, in the engine compartment revealed the rod connected to the end of the steering cable is bent. <br /><br />Obviously, I need to replace this part. I have removed the steering cable from the steering wheel. I have loosened the retaining sleeve where the cable enters the tube. I have also unbolted the bent piece from the linkage that connects to the lower unit steering arm. <br /><br />Is there something special to remove the bent piece? The bent piece will enter the tube, but I cannot get the end (where the bolt hole is) to go in. I am betting this part unscrews from the cable? Is the bent piece a part of the cable?
