Hello,
I have determined my steering cable is corroded/frozen and I would like some information on removing it, this is a '61 larson boat with a '72 evinrude 100 hp Starflite, I removed the cable from the engine, and see how it slides out thru a pipe that leads to the steering unit, however the attachment at the steering wheel is more complicated, the cable at this end is attached to a larger cylindrical metal tube (which I would describe looks like a silencer) attached with a nut; I thought the cable would detach by this nut but as I turn the nut the cable also turns), this unit connects/inserts into the steering unit with 4 bolts holding it in (it appears). I don't want to remove anything I don't have to, so any information would be greatly appreciated. I have studied similiar threads and I don't see any pins that appear to hold the cable in. The steering unit doesn't look accesible without cutting a part of the dash out so I'm hoping there is an easier trick to this part, thanks
Janus
Janus
