steering cable
rolmops
I am considering changing from an old steering cable system to either a rack or rotary system.So far I found out that a rack is a bit cheaper but not enough to be a mayor factor.
Could any of you gurus tell me the pros and cons of the two systems?
I intend to use one of them on a 17 foot 1964 Duracraft Orion partial V hull with a 1986 50 horse Evinrude.
thank you,Rolmops.
Re: steering cable
Ayuh,........
It's not so much the Pros or Cons,.....
It's All about the Space Available under the Dash..........
Racks are Too Wide for many app.s,.....
tashasdaddy
Re: steering cable
i only use the rotary system, it is user friendly, much easier to install. on my 58 duracraft, i still have the pulley cable. trim tab adjusted so i can turn wheel loose. would love to see pixs of yours. see mine and post yours here: http://forums.iboats.com/Duracraft
