mandoman68
- Joined
- May 20, 2009
- 38
I have a 69 merc 1000. 100h.p. Motor wont turn right or left. Lube the fitting but still wont turn. I imagen it's corroded.What is the repair for this?Thanks.
Disconnect the steering at the motor. The motor should now turn back and forth very easily. If not there should be a couple zert fittings where the motor turns. If it does turn freely then replace the steering cable. You might get lucky if you pull the cable from the motor then clean and lube.
I tried heating the swivel shaft and it began to loosen up. Once it cools it gets stuck again.What about removing the zerk and adding some penetrating oil like PB Blaster?Or something "warmer" than propane?Thank You for your help.
