Steering issues
drawley
my 16ft lund steering is problematic. When steering to right or left while going fast the steering does not work. The wheel turns but the motor has not. I replaced the cable 3 years ago because the steering wheel was so hard to turn. Maybe I missed something while installing?? I can simulate that action by holding the motor while someone turns the steering wheel. Also when turning the steering wheel it never will stop. On a car it goes only so far right or left then no more. Can anyone trouble shoot my issue? Thank u, David
Ayuh,..... Welcome Aboard,... Sounds like an internal Helm problem,.....
drawley
Bondo, this is an old 1983 lund. Just a simple rack and pinion steering cable.When u said it may be a helm issue can u elaborate? I'll add my boats trim is only adjustable manually at the back of boat. An engineer friend thought the steering issue is causing the trim issue.
