accentphoto
- Joined
- May 4, 2011
- 128
In the midst of working on this recently acquired Grumman 5.0, I noticed that the motor never turned and the steering wheel seemed locked. This motor is steered by a rotary steering unit that has the steering cable that goes to the steering tube on the motor.
Here is the questions and or problems and please use the photos for reference:
1. Is the steering cable from the steering wheel physically connected to the steering link rod or is there some type of hydraulic method involved?
2. Should the steering cable come out mostly but not all the way without removing the nut in the photo or is there a problem inside the tube with the steering cable?
3. As you can see, the steering cable can be pushed in the tube and pulled out but the steering link rod does not move or feel connected in any way to the steering cable. What could be wrong? Any special way to clean and re-lube this area?
Thanks!
Thanks!
