Re: Steering Locked Up
I'll get some pictures tomorrow when I open it back up. The end that connects to the motor has an aluminum cylinder on it (not sure of the technical term here?) that looks like it's supposed to move back and forth. It's this piece here
The wheel moves freely. I am going to take it apart to see if I broke the rack and pinion portion of it when I tried hard to move it. It's hard to tell from the iboats description of steering systems what I need. They list NFB racks and just standard rack and pinion. Will either work?
Ayuh,... The aluminum tube, a tilt tube on an outboard, is part of the transom assembly, not part of the cable...
That's the most likely spot for corrosion to bind things up....
Yes,... Either will work....
The NFB helps tame the prop torque steer,...
If ya got P/Steerin', ya don't need it...
Without P/S, it helps Alot...
