Steering Lube & Maintenance
eot
I recently purchased a 1986 17' Bass Tracker boat that had been setting for a couple of years. Did all the maintenance I could come up with including greasing steering parts. Still, the steering is stiffer than I would like. Boat has Rotary steering. Coming off the rotary box is a clear plastic tube with a cap on it and appears to have the end of the cable inside. Is this the lubricating point for the cable and box and if so, what lubricant do I use? Also, with the exception of when it breaks, how do you know if the entire cable should be replaced? Thanks!
pmueller
Re: Steering Lube & Maintenance
eot, welcome to the board. I'm not familiar with your particular set-up, I'm sure more knowledgeable folks will add to this, but my manual calls for the following: steering link rod pivot points use light weight oil, steering cable grease fitting use anti-corrosion grease or 2-4-C maring lubricant with teflon, clean hinge tube and lubricate with waterproof grease.
BillBill
I think there was an article in one of the boating magazines recently. I will look when I go home and see where it was....
the "tube" you mention is for the "tag-end" of the cable... it has to go somewhere when you turn the wheel.... When the cable gets "tight", it's telling you it's time for a new one.... you'll find, it's cheaper,+ easier to replace the "whole" system, than just the cable....new cables cost about the same as a complete system... about $100. to $150.
