Re: Steering near impossible 97 (18') bayliner with 120 force
Is the helm easy to turn on land vs water? If not, then do the following.
I suggest that you disconnect the steering cable at the engine and determine if your problem is with the cable or with the engine King pin.
If it is hard to turn in the water, you need to give me more info as which direction it is hard to turn.
John
