Steering Problem
rutcutter
I have a 2005 Bentley Cruise 200 with a 50 hp mercury 2 stroke. If you turn the steering wheel at very low rpm it is fine. At high rpm there is a popping noise when the wheel is turned. I cannot figure out how to access the steering mechanism. Do I have to remove the whole console? I would also like your opinions on what my problem could be. It does not have hydraulic steering.
Thanks.
ezmobee
Re: Steering Problem
Sounds like you may have stripped a tooth in the helm. You'll either have a rotary or a rack helm.
Rotary:
Rack:
If it's a rack, it's possible the bolts that hold the helm to the rack have loosened and the gear is slipping.
EGlideRider
Does the motor 'follow' the wheel or does it tend to straighten out?
lmuss53
There should be a cover or something on the console that you can remove to access the helm.
boatman192
On a bentley you have to remove the top of the console to get too the steering..
