Steering, push pull or Hydro?
earringboy
I have a 18ft aluminum Sylvan 1979, Merc 115hp 1986 and now have Teleflex 3 turns standard roatary type steering. It has slop, I can move the motor 1/4 inch or so before the steering wheel moves. Can that be tightened up in any way or is everything just worn out? I was thinking of replacing with a NFB version of the rotary or going to a Baystar Hydraulic set up. I assume the hydro is also no feed back and would have a much longer life than a cable type. What do you all think, pros and cons for each, aside from the fact that the baystar is way more money.
alwims
Re: Steering, push pull or Hydro?
I just finished, a few days ago, installing the Baystar system. I'm retired so I get to fish every day if I want to. I am so happy with my new steering, it will be the first upgrade on every boat i own from now on.
earringboy
alwims, what size motor do you have? The Baystar is no feed back right?
earringboy
Nice motor! How much effort to turn when running wide open?
alwims
None. It turns just like my GMC Envoy that I pull it with. If you ever go Hydro you won't go back. It's a little expensive and you really have to make sure you've got all the air out of the system, but it's well worth the cost and trouble. Someone recommended I take mine to a shop and have them power bleed the system, but my fishing budy and I did it ourselves manually and it works perfect.
earringboy
I think you are right, West Marine did have the best price, plus they run 10% off alot. I think I will be doing that as soon as I can.
