I have full turn to right,but not left. multiflex manuel steering thru tiltube. between end of steeringcable and engine there is a link,mine is 280mm long,do i hvae to get a 300mm link to solve this problem? engine is johnson 85esl73m
Sounds like it. But does your motor have two holes in the steering arm? If it does, use the one closest to the motor for full steerage. The outer one is for a dual engine tie bar. But you still need the correct drag link.
