steering questions
RooSmith
i used my buddys boat the other day and realized my motor (1973) johnson 20 hp tiller handle is very difficult to move from side to side well to steer, what can i do to fix this
also my prop is damaged, bent on the ends a little bit and bad cupping, does anyone know anybody in jacksonville florida that repairs or rebuilds props
tashasdaddy
Re: steering questions
grease the grease fittings on the swivel shaft.
Ellis Propeller, i believe on Phoenix St. or Jacksonville Prop, on 8th Street
robert graham
Maybe some penetrating oil like Liquid Wrench, and some grease in the zerk fittings to loosen up the motor pivot bearings. Regarding the prop, maybe just buy a new one and keep the old one for a spare. You could probaly get a new one for that motor for $50 or less. Good Luck!
wilde1j
If your motor has a steering friction adjustment, it may be too tight.
tashasdaddy
does not have adjustment. light heat from propane torch, on swivel tube and work it, back and forth, then force grease thru it.
F_R
Sure it has a friction adjustment.
When you get done with all the "easy" cures, you will have to disassemble it and clean the corrosion out from around the upper pivot liner. Happens all the time in salt water.
