Steering really tight
trent_tweeter
How do I go about freeing up a real tight steering system. 175 hp johnson on a 17 foot deep v with what I assume is rack and pinion at the helm and a flexible cable to the motor?
ezmobee
Re: Steering really tight
People don't typically have much luck freeing up or lubing stiff cables. Usually replacing the cable is the best option.
dforcinito
See if the actual cable is jammed or the rod that goes into the tube is sticky. If its the cable, then the cable needs replacement. You can spray some PB blaster on the tube and see if it cleans up.
ajgraz
Agreed, it's not necessarily the cable. Could be junk inside the tilt tube or a dent in the tilt tube catching the steering ram at the end of the cable.
'78 Crusader
If it's been a while since the cable has been replaced, it's most likely a bad cable and cleaning it up will prove fruitless. If after you've looked at the tube and also looked for obstructions and find nothing....don't bother wasting your time on the cable itself....replace it.
Been down this road a few times, most recently with my Jetboat...put a new steering cable on it in Septmeber 2010 and am very glad I did.
Cannondale
Agree with all the above.....but you have ensured you've been lubing the kingpin on the motor, right?
