Re: Steering saft question
That is a LOT of play! You can try retorquing the two gimbal ring clamping screws (at top of ring) to 55 ft lb (nuts on back). It might tighten it back up, but it may be too far gone, and if it is the steering arm it will not help. Let us know how that works out before you tear it apart. Either the ring or the lever the fix is the same.
