I am in the process of trying to prepare my boat to actually use it instead of working on it. (HA)
I need to remove the center console that sits on top of the last section of Plywood deck that needs to be removed to facilitate plywood replacement..
The console is bolted through the plywood into Aluminum supports.
Once I remove the console, I can remove the plywood.
FUEL tank is below this section of deck.
I have photos of INSIDE the console area and need advice on:
Disconnecting the steering connections
Disconnecting the Throttle / Gear shift mechanism
http://www.nefla.com/boat/console.htm
Any additional suggestions will be appreciated
Thanks,
Bill
Jacksonville Beach, Fl
Thanks,
Bill
