saltfisher
- Joined
- Aug 22, 2007
- 111
Just got a 1988 tracker 1800 fiberglass boat with a 150 black max. The owner told me that it steers all the way to the left, but when you steer to the right it only goes about 3/4 of the way then stops. So you cant turn as sharp. I got it home and tried it and he was right. I seen a lube fitting and lubbed it. That made it easier to turn to the left, but then it wouldnt steer at all to the right, and then forced it a little and then it started to steer. BUT... All the lube I just put in the fitting was comming back out as the motor was going back to the right. Some was fresh mixed with older dirty lube. It still stopped about 3" short on the slider shaft (same place before lubbing). What could be the problem? I was thinking maybe some sort of blockoff may need adjusting? or maybe just old lube is caked on that side making the slider shaft (dont know proper name) stop short. Any ideas?
Thanks
Thanks
