Steering
sdelamarche
21 foot Four Winns inboard, 220hp 4.3l V6 OMC…. The issue I am having is that I am hearing a high pitch “wine” from the rear engine compartment which is steering related. I believe I have power steering and not hydraulic because I checked the fluid level and all appears to be ok.. When I’m running at about 3000 rpms and turn slightly to right I hear the pitch I hear nothing when I slightly turn to the left. I hear the same pitch at lower random rpms as well….
Do I have air in the line??
If so how do I bleed the system??
How do I check to see if I have a leak??
Can this wait till end of season? Will I be OK?
Any internet addresses for troubleshooting would be greatly appreciated.
Don S
Re: Steering
Sounds more like a bad gimbal bearing or ujoints. Pull the outdrive and feel the gimbal bearing and ujoints and check the bellows for water.
