SmokinBarrel
- Joined
- Feb 17, 2004
- 38
I have a question?
I am going to use Polk MM651's (speaker), and so I will need an amp to power them correctly. I was informed that the ideal amp would be 100wx2 (RMS) - 150wx2 (RMS). The speakers are rated 100w (RMS) - 200w (Max), with a 2.7 ohm rating.
I am only going to have 2 speakers and no subwoofer - for know.
Can I use a 4-Channel amp at 4 ohms, so I only use 25 amps versus 50 amp draw at 2 ohms? It is my understanding the 4 ohms usually requires roughly 25 amps, and a 2 ohm setup will require roughly a 50 amp draw. The best amp I found at a reasonable cost is 60 - 90wx4 (RMS) at 4 ohms. I am thinking this will be sufficient enough, especially at the higher end RMS 90wx4.
Question:
1. Can I still use a 4-Channel amp for two speakers? It seems the wattage is lower on a 4-Channel for lower to mid amps.
2. Would 75wx2 (RMS) be sufficient? I was told that if you're not close to the speakers minimum (RMS) wattage, it has negative affects on the speaker (not as efficient - causing a fray at the edges)
As a note: I was told by Polk that the db651's where not completely sealed around the edge or in the middle - cannot remember. Anyway, the reason he recommended the MM651's because they're completely sealed. Otherwise, I would go with the db651's (rated at 4 ohms) because they have great reviews. But, the db651's are not sealed (100%), but will only be used around fresh water.
Music listening: Radio and Easy listening (75% of the time), Booty Music (for the ladies) (25%) of the time. Most likely 1 - 1.5 hours maximum continuous booty music.
Question:
