stereo wattage loudness question
natedog337
My Jenson Marine radio 40x4 watts died this year. Purchased a unit from West marine that is 70x4 watts. Just wondering if this will have a significant sound difference as far as clarity and loudness because of wattage. I'm not familiar with how wattage pertains to this and If it will necessarily make that much of a difference.. Thanks
sweet addiction
Re: stereo wattage loudness question
What you want to look for is the RMS power. That is the continuous power, the power rating that actually matters. You will find it in a table somewhere in the owners manual. The next value you want to pay attention to is the THD (total harmonic distortion). This is what tells you how clean the power is. The cleaner the power the better/louder the sound. You will also want to know how much power your speakers can handle. Again you want the RMS rating of the speakers. You will find this on the back of the speaker. If they are factory speakers they will most likely have the max power rating on them. If that is the case a general rule of thumb is that the RMS rating of a speaker is usually 1/2 of the max power. So basically if you want a good sounding loud stereo you want to match the RMS power of the your speakers to the RMS output of the head unit. If your stereo(head unit) can not do that then you will want to add a small amp to the system as under powering speakers is often worse than over powering them. :D
sweet addiction
What is the brand and model of the new stereo?
sweet addiction
So I looked up all the info on what you have. The deck is putting out 60 watts RMS to each speaker and each speaker can handle 75 watts RMS. I would recommend a small 75X4 watt amp but if you don't want to mess with it you still should be fine. Just pay attention to the amount of distortion while playing it loud. Those are nice speakers and would hate to have them get ruined do to too little power.
gm280
Speaker volume can be determined by math. For instance, you purchase a speaker and it states that it has a SPL (Sound Pressure Level) of 96 DB at 1 watt/meter. That means at one watt of input power to the speaker you will hear sound at 96 DB (decibel) at 1 meter away. Next look for the total and RMS (Root Means Square) levels that speaker can handle before the voice coil will become damaged. In the above scenario let’s say that speaker can handle 100 watts RMS. So now you want to know how loud that speaker will sound. Again it is simply mathematics. For every 3 DB increase of SPL, it takes double the power. So if the speaker can output 96 DB at 1 watt. It will put out 99 DB at two watts, and 102 DB at 4 Watts, and 105 DB at 8 watts, 108 DB at 16 watts and so on. See the trend going on. So if you work out the math, this speaker can output a max of around 115-116 DB max at 100 watts input power... Trying to push further will damage the speaker beyond usability. The ohmage (resistance) of the voice coil is the load the amp will have to drive. If your amp can’t handle anything below 8 ohms, a 4 ohm speaker will damage the amp because the lower the resistance level the harder the amp has to work to produce power across such a low resistance. The closer you get to zero the closer it is to a short circuit condition. Some very high quality amps can drive near zero loads. But you will pay dearly for such capabilities too. The best sound will be a compromise of power and speaker design and handling capabilities. A speaker that can handle tons of power will not sound as good at lower levels simply because it take so much power to move the heavier cone and voice coil. Nothing is free even in the electronic world. So match those two (amp and speaker design) and you will enjoy quality sound at any level at its best for your money outlay...
