Five Spice
- Joined
- Mar 20, 2011
- 12
Have driven myself crazy with a pole light that won't work. I have new switch, new pole light and base. Th light is getting juice and have tested the bulb which works. The foreward navigation lights work properly, but the anchor light will not illuminate in either position of the 2 pole switch.
When the pole is out of the base, the ground is not hot, as it should be. However, when the pole is inserted into the base, the ground goes hot. I re-wired the ground straight to the negative battery terminal before I realized the pole completed the circuit. This is exactly what happened with the old base before I spent $30 for the new one. Is this what's supposed to happen? I'm at my wits end and ready to duct tape a flashlight on a broomstick.
