I have a 1986 OMC Cobra with a 3.0L 140hp inline GM 4 cyl. engine on a Rinker. We have had water leaking into the bilge area for several years. I have never been able to figure out where it is coming in. Today (with the boat out of water) I tilted the front end high and put water into the bilge area to see if I could see water coming out. Water was coming out of the annode area mounted under the plate that is attached to the transom. I removed the annode and there are two holes that go inside the boat. I suspect that is where the leak is but I don't know.<br />Any help would be greatly appreciated.
