GCartwright
- Joined
- Jul 1, 2012
- 149
I just removed the outdrive off my 7.4L Bravo 1, first time doing it so I could use some advise.
I have water in the bilge which I thought was going to be from a leaking bellows, But after inspection,all bellows, ujoints, gimbal bearing are all in good shape.
Can the leaking steering swivel shaft seal only be diagnosed as bad if water is enters the boat through the transom? Not sure if it has ever been rebuilt as the boat is fairly new to me.
The swivel shaft seem tight, very little movement in any direction
