sterndrive removal for impeller
1980Galaxy
I am trying to replace the water impeller and housing in the outdrive but i ran into a problem. i took the 6 bolts off and also the 2 trim arms that are connected to the drive. i also had it in forward gear. the drive is a little loose but i can't get it apart.
i believe i am doing it correctly but maybe i missing something.
also, i noticed a smaller "cover" i guess on the top of the outdrive (right in the middle above those 6 bolts). it is on there with 4 'star-shaped' bolts that i didnt have the sockets to take off. whats inside there? could that be where the impeller is?
by the way i have a 1980 galaxy with a mercruiser 120 engine. forgot to get the s/n off the outdrive. all i know is that its a mercruiser.
thanks for your help.
dubs283
Re: sterndrive removal for impeller
you are on the right track. if the drive as moving away from the bell housing you have diconnected everything correctly.
it is probably stuck due to a lack of maintenance of the engine coupler i.e. not being greased for a long time.
place a short 2x4 in between the front edge of the top cap (where the star shaped bolts are) and the gimbal ring.
grab the back end of the drive and move upwards wedging the 2x4 in between the top cap and gimbal ring.
use force and the drive should slid off
you arent going to break anything.
the water pump is mounted on the top of the lower half of the drive, you will need to separate the drive when you get it off to service the water pump.
be sure to replace the water pump base assembly too, it is sold seperatly from the water pump kit.
Matty8251
If you are trying to remove the stern drive and have all the boalts holding it on and the trim arms are off, then you need to put a 2x4 on a angle at the top of the drive then manualy tilt the drive up the get the stern drive to seperate from the gimble housing. After that I am no help I have a OMC stern drive and the removal is the same but the water impeller is on the outside of the drive so it can be changed without removal of the drive. The top cap you are talking about is the top of the gearcase. You should not have to remove that. If you do you will see the pinon gears that come in the drive.
1980Galaxy
thanks for replying so quickly. im glad i had it right and will give it a shot next time i have a chance. thanks for the help.
also, i am assuming i will need a new gasket for where the drive separates from the boat, correct? and also what other gaskets or orings or anything else would i need to get so i am prepared when i get this thing off?
dubs283
drive to bell housing gasket set.
check engine alignment
GREASE ENGINE COUPLER!!! quicksilver engine coupler spline grease (blue)
grease u-joints and gimbal bearing
check condition of bellows
pressure test drive after re-assembly
1980Galaxy
one more thing: does the gear lube need to be drained before doing this or can i leave it in there? i just changed it and dont want to waste it if i dont have to. i also dont want to make a mess if its gonna go all over when i take it off.
thanks
1980Galaxy
wow, that was so fast i almost feel like this is a chat room haha. thanks for all your help
Bt Doctur
You do have the manual, Right?
fishingman220
if the drive is off, can you put some grease into the coupler inside the splines, or do you have to pump through the fitting inside the engine compartment? sorry to jump on your thread but i figured you would wnt to know as well.
