Stick Steering System
biloxiriver
I have an old 15' boat that at one time had a stick steerin system in the forward area of the boat. Does anyone out there know where I can find these systems now???
roscoe
Re: Stick Steering System
Fisher boats had stick. They still make them. <br /> http://www.fisherboats.com/index.cfm?fuseaction=home.boat&nav=30&boat=591 <br /><br />Here you go, a whole new system for $199. Check out page 2 also.<br /><br />https://www.surplusunlimited.com/Merchant2/merchant.mv?Screen=CTGY&Store _Code=1&Category_Code=2200-100<br /><br />Here is the manufacturers site, it has some accessories that you may need, for mounting, etc.<br /> http://www.fallingwatersgolf.com/acc.html
aspeck
I had one of them on an old boat of mine - only rated for 40hp - the steering, not the boat. Got tired of fighting with the 40 merc, so I put a 55hp Johnie on it. Too much torqque, kept snapping the steering - no fun at WOT! Changed it out for a steering wheel system (mounted vertically on the side of the hull, where the stick used to be) - just used the steering wheel like a wheel chair. It worked and was a real conversation piece at the lake.<br /><br />roscoe has some good links if you want to keep it stick.
biloxiriver
Thanks for the replys. After hearing aspeck's comments though I guess I will stick with the tiller steering.
