SHickey
- Joined
- Apr 29, 2011
- 263
:grumpy: Well fellas I put my '87 19' Blue Fin 2.3 Cobra (vertical drive model 984540) in the water this afternoon and I am still having a shifting problem. This spring I replaced the ESA module and that seems to be working fine. Basically from N to D it's fine. From D to N there needs to be constant pressure and jiggling of the shifter handle and after @ 10 seconds it disengages. From N to R again I need to keep pressure on the shifter and eventually it engages into R. Getting it back into N is another struggle with the shifter.
Do you guys think I will need to adjust, lubricate or replace the actual shifting cables and if I do, could a tinkerer like myself tackle this kind of job armed with a Seloc manual or should I leave this to the professionals??
The motor and drive seem to be operating flawlessly but getting it into N and R is a real kick in the butt. And please don't tell me the cable that may need replacing is $750.:faint2:
