The automatic choke on my mercruiser 233 (Ford 351W) sticks open when the engine is cold.
I can get it to fall back closed by wiggling the throttle linkage on the carb, but It always re-sticks open when I throttle-up from the helm. (like when I try to give it some gas for starting).
I'd like to be able to start the engine cold without having to open up the engine compartment and fiddle with the carb.
I tried adjusting the idle screw and the bracket that holds it, but I haven't had much luck. I was looking into the rebuild kits, but it doesn't look like those include the idle screw or its cam (Am I wrong here?).
Obviously the choke worked properly at one time. Can someone please help me to understand what's causing the problem and how I can fix it?
