sticking voltmeter
mkfs9
ON using my 4.3 ltr merc for the first time this year i noticed the volt meter stuck on 12 v.It did move up to around 14 v but it took around 15 mins to do this.The alternater is 18 years old now.
Re: sticking voltmeter
Ayuh,........ 13.6V is where it's Supposed to get to.........<br /><br />I Don't see any Problem............ ;)
mkfs9
It did rise up but it should move up straitaway i would think like it used to do.
I/O WALDO
Yer batt-tree was in a low state of charge.
mkfs9
I hade just fitted the battery after charging it i dont think this is the problem.It turned the engine over fine.
mkast
First off, the voltmeter on board the boat is very inaccurate, used for reference only.<br />Secondly, the state of charge, as measured in the battery, can differ between the battery charger and the regulator on the alternator.<br />Try using a digital multimeter directly on the battery terminals, before and after starting the engine. Then check what the voltmeter on board is reading.
ron7000
Banned
I believe what you described is coming from the brushes in the alternator. what happens is when you start the engine and stay at a low rpm the alternator won't charge, until you rev the engine up over 1000 rpms it will and that's when you see your volt gauge jump from 11-12 up to 13-14 volts. While the volt gauges are not that accurate, you will be able to notice the needle jump and if you do that's the sign the alternator is in need of maintenance. Eventually you'll have to rev the engine higher and higher to get it to charge, then it won't charge at all.<br />I don't know what type of alternator it is, guessing since you say it's 18 years old it's self-exciting. But if it isn't, then all that could be the problem is a loose wire connection, so check all your wires coming from the alternator going to wherever are secure and contacts are clean. If that don't do it, don't feel bad. 18 yr service life is pretty good.
KaGee
Originally posted by mkast:<br /> First off, the voltmeter on board the boat is very inaccurate... Try using a digital multimeter directly on the battery terminals, before and after starting the engine. Then check what the voltmeter on board is reading.
What he said.
