I was wondering if one of the Cable Buddy systems with the nut and seal and lube you put in would help instead of replacing the cable $30 vs $150 if it works would be great What's your opinion it's a 150hp Fastrike dual cables
clean the cable and the tilt tube. then reinstall with the cable buddy. 99% it is sticking in the tilt tube. disconnect the cable at motor, turn motor and then turn wheel see which is sticking.
