Re: Sticky trim-tilt switch
Depending on what type of connection , you have at switch.<br /> If theres any exposed screws , ring, etc. <br /> After clean-up , coat whole thing with Liquid elect. tape.<br /> I use, 3-M, its brown /clear , . I like it because it peels right off , if necessary. <br /> Usually I'll put at least 3 coats on almost every connection. <br /> ie: engine grounds, coil to head, starter lugs, solenoid , trolling motor foot control conn., all battery connections, etc. etc.<br /> <br /> Good-Luck,
<br /> KYHunter
