Leardriver
- Joined
- Oct 7, 2008
- 380
Hi guys!
Sea Ray Sundeck, 496 mag, motor OM672099, drive OM701661. Fresh water, under 100 hours.
The steering effort at the wheel is excessive. I have lubricated the ram at the actuator behind the engine, drained and refilled the power steering reservoir with synthetic, started it, moved the wheel lock to lock to mix the fluid, drained and refilled again. The pump and belt doesn't squeal, it just has a heavy feel.
Is there a bearing under the steering wheel? Hidden grease zerk? Can I get a new steering cable and fix it?
Thanks for your suggestions.
