Stiff shifting
jmfrost
I'm having a problem shifting into gear on our Mercruiser Alpha I Gen II. I originally thought it was the plastic bushing inside the remote because because it was cracked. But replacing that didn't seem to help. Any other ideas on what would make shifting so stiff?
Bt Doctur
Re: Stiff shifting
bad upper cable
bad lower cable
corrosion in the shift mech
fused lower cable from a overheat
jmfrost
Re: Stiff shifting
Ouch...neither option appears to be an easy or cheap fix. :mad::(
