1987 Force 50 HP.
The steering on the engine is stiff. I know it is the engine (kingpin) and not the cables because I had to take it off to replace the transom that rotted out.
What I wanted to do was take a heat gun and heat it up, as I learned from other threads, and then take some compressed air and shoot it in the grease fitting to force all the old nasty stuff out. Then mix some PB to a grease tube and put in some new stuff. Is this something that could work without damaging?
I need to get it loosed up because when we pulled the engine off the back, the steering arm actually snapped off right in front of where the cover sits. Which, by the way, does anybody know what kind of metal this is because it needs to be welded back together? Fridge magnet didn't stick to it, but those magnets aren't very strong in the first place.
Thanks.
Thanks.
