Stiletto Advantage 2 on a 98 force 120 hp ?
Bustedknuckle84
1)Can this Stiletto Advantage 2 prop fit my 1998 Force 120hp motor?
2) How can i contact the manufacture of Stiletto?
3) Which hub kit will i need?
Here are my specs
Manufacturer: Force
Horsepower: 120 HP
Years: 1995 & Newer
Model: Mercury 4-? Gearcase Outboard
Specs: Thru Hub Exhaust & 15 Tooth Spline
Propeller Pitch: 17?
Diameter: 13 - 1/4?
Pitch: 17?
Blades: 3
Rotation: Standard (Clockwise)
Here is the prop specs:
http://boatpropellers.iboats.com/St...20317/?**********=447717707&*******=423884123
SKU:#20317
Manufacturer: Stiletto
Brand: Advantage II
Material: Stainless Steel
Diameter: 13 - 1/4?
Pitch: 17?
Blades: 3
steelespike
Re: Stiletto Advantage 2 on a 98 force 120 hp ?
Didn't find advantage 2 but advantage Q was same prop and hub number for 98 Merc 115 and Force 120.
Bustedknuckle84
yeah i seen that as well, wonder if that hub will work on the adv 2 prop?
