1976 85hp johnson. No power. No 1 cyl not "firing" Cleaned carbs., changed power pack with a used one from a dealer. Spark using spark tester real good. compression on all cyl. right at 145. Tried it out today--crappy. came home and did spark test again--good. Cranked it up at idle and pulled the wire on each cyl while at idle. Only on no. 1--no difference. How and what can I do next? I've been reading the other posts hoping to get some info.<br />Thanks<br /><br />ted
