Still can't get motor up.
billum
Have all electrical unhooked, still can't get motor up. Drained all fluid out of pump, seems to be hung up on one trim pump. This is a 1990 120 Force, need to change impeller and am in middle of overhaul so don't have use of hydraulic tilt and trim. What do I need to do to lift motor by hand?
12Footer
Re: Still can't get motor up.
Loosen the hose connection at both rams, and be prepaired to get a "hydrolic-shower"....<br />Well, it's possable anyway.<br />You may have to bleed the air out afterward, but I think it's the only way.
billum
Hey 12 footer, thanks I thought that was the only answer but wanted to hear it from someone else. Thanks again, I will try it.
